- 25 Sep 2012
- Scotland
Hi all.
I recently upgraded my PC with a 970 and a 512gb MX100 SSD. The motherboard I am using is a Gigabyte Z68-UD3-B3 and a 2500k CPU. I had to update the bios on the motherboard because it took ages to boot and I couldn't access the bios after installing the 970. This is where the problems started.
I was having random lockups when just browsing the web. I have found that I can consistently cause the computer to lock up by running prime95 for about three and a half minutes.
Here is a list of things I have tried to resolve the problem and none have worked:
Reinstalled Windows 7 and changed the 970 for my old 7950 without installing graphics drivers.
Changed it back to the 970 without installing graphics drivers
Swapped back to my older Sandisk SSD and did a fresh install of Windows
Made sure all of my Ram timings were correct etc.
Flashed the Bios back to an earlier version
Swapped PSU's
Reapplied thermal paste to CPU heatsink
I have run out of things to try. What do you guys think? Have I missed anything?
Swapped PSU's
