Computer Lockups
12 Jan 2006
I am getting random lockup's,
i ran memtest and got no errors so it cant be the ram
-AMD Opteron UP 165 Dual Core San Diego 1.8GHz 2MB Cache (Socket 939) - Retail (CP-151-AM)
-DFI LanParty UT NF4 Ultra-D (Socket 939) PCI-Express Motherboard (MB-014-DF)
-HIS Excalibur ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-048-HT)
-Western Digital Raptor 74GB WD740GD 10,000RPM SATA 8MB Cache - OEM (HD-015-WD)
-G.Skill 2GB DDR HS PC3200 (2x1GB) CAS2.5 Dual Channel Kit (F1-3200USU2-2GBHS) (MY-007-GS)
-Seasonic S12 600W Silent ATX2.0 Power Supply (CA-002-SS)
-Zalman CNPS9500-LED Aero Flower
i have the cpu at 2.3Ghz and it doesnt go over 45oC even at full load
I am running the newest Omega drivers
any suggestions of what it could be?
are there any tools to test all the components seperately/together to see what is the culprit
ummm....
Double check all your temps including motherboard, CPU, Graphics GPU EVERYTHING and make sure nothing is getting too hot !
It COULD also be a software problem, try a system restore to earliest date possible.
thing is this is a brand new install
only things i been playing with is the Ati drivers as i had some problems finding stable ones
Been playing godfather for 3 hrs
CPU: 38oC
PWM: 51oC
Chipset: 51oC
Gfx Card: 62oC (is this hot for a X1900xt card?)
CPU: 38oC
PWM: 51oC
Chipset: 51oC
ya should be fine with them temps, how much vcore are ya using, have ya tried prime95 nthat may give ya a clue
oki i will give prime 95 a go :)
i have set it to 1.40 v in the bios but i havent really seen it go above 1.37 yet
