Computer no workie...
14 May 2009
Hampshire
Morning gents,
Yesterday i was playing BFBC2 when the game froze. I did a CTRL+ALT+DELETE and then artifacts started to appear, so on my screen i had bits of BFBC2 and bits of Windows showing.
I turned off the PC and turned it back on and i got the BIOS screen but there were loads of little blue dashes down the screen. I turned to PC off and took out the card (4870x2) and the PC worked fine. Put it back in and all i got is the black screen PLUS none of the USB devices worked, yet they work without the card plugged in.
Is this a GPU issue, or could it be the mobo/PSU?
I've created a thread asking what GPU to replace the 4870x2 with here but if a mod see's this then you might as well close that thread and put a link to this one if you would be so nice :D
Helps!
Thank you,
Cas.
Definitely a graphics card issue. If it's doing it in bios it's not a driver or overheating issue either. You need a new card I'm afraid.
I used an old 8600GTS and that worked without fault either.
I've just ordered a GTX 480 as i want to go back to Nvidia, never had a problem with any of their cards.
Still, £200 is a lot of money :(
