I had my i5 working and stable at 4.2, I tried 4.4/6/8 with no luck at all. Put it back down to 4.2 and it doesnt boot. Returned to stock, still no luck, it just always resets after the bios logo
Get the hammer out I heard somewhere that you can do something to your motherboard to restore it to factory settings other than doing a CMOS reset. I don't know how though .
Nothing has changed, all I did was after running 4.2 for a while. Reset the pc, put it up to x44 and tried. Kinda confused....I dont wanna reinstall windows a 3rd time. Im sure its not an OS issue
do you have a spare hdd to try as if your doing a fresh install but dont complete to see what happens just if it will allow you to do so if it does then something has happened to you OS on your ssd
I have had this kind of thing before and removed the CPU and Batt and then the system would boot, but would not boot if just removing the Batt for awhile, not sure why but it has worked for me
