- 8 Nov 2008
Ok, so I sent my old PC to my friend, was working perfectly when it left here and now that he has got it, it is not working.
The Problem
When he turns the computer on all of the fans come on, the HDD light is solid but there is nothing on the screen. It will not even get to display a post message or anything, just "No signal".
To try and fix the problem he has checked all cables are correctly plugged in, cleared the cmos, reseated the RAM, tried both RAM stick individualy, reseated GFX card, tried it in a different PCI-e slot, tried the same with another GFX card. Brought it to a PC repair place and they said the mobo if dead because there are no beeps, but seeing as it is in an Antec 900 which does not come with a speaker, I need some extra help.
Specs incase you need em.
Antec 900
Asus P5N-D
q6600 with stock cooler
500GB HDD
4GB patriot ddr2 800MHz
750 watt corsair
GTX 260
The comp is a few years old but was working perfectly until it arrived with him.
Anyone got any ideas?
Thanks in advance.
The Problem
Antec 900
Asus P5N-D
500GB HDD
750 watt corsair
GTX 260
Thanks in advance.
