Computer not powering up
Permabanned
24 Apr 2010
Lancashire
Hi, I wondered if anyone here could give me some advice.
I have a computer which is about 18 months old (just) and was a custom build that I bought from a friend of a friend, however, it's recently started playing up.
Basically, when I try to turn it on, the light comes on but nothing starts up (no bleeps, fan etc). So I try turning it off at the mains and try again - eventually, after up to 20 attempts, it starts up.
Can anyone make any suggestion as to what may be causing this?
Thanks
the first port of call is to run pc on absolute minimum i had this problem once and it turned out a usb mouse was causing the issue go figure
