Hi, I'm hoping someone might be able to give me some advice for what my next debug steps are...
My (quite old) computer was working this morning (playing games etc). However, turning it on this afternoon and it does not start:
I have tried replacing the CMOS battery. No effect.
My gut tells me that I have a dead motherboard/CPU, but it could also be a faulty power supply.
From these symptoms can anyone recommend what is most likely faulty, or if there is anything else I can try?
Specs:
i7 6700k
Asus Pro Gaming Z170 motherboard
16 GB RAM
500 GB NVMe SSD
500 GB SATA SSD
Zotac RTX 4070 (the only upgrade I've done)
750 W EVA power supply
- Press power button
- Fans turns on
- Motherboard CPU_LED turns on (not sure if this is normal or not), motherboard manual does not give any detail on what this means. But I'm guessing it could be a CPU issue which in turn could be a motherboard/power supply issue?
- Graphics card RGB flashes yellow twice (not sure if this is normal or not) and then goes to its RGB breathing mode
- No output to display, so I can't get to the BIOS
- After a 5-10 seconds the computer turns off
- After another few seconds it turns on again with the same behaviour
- This loops a number of times and then it just turns off for good
Specs:
i7 6700k
16 GB RAM
500 GB NVMe SSD
500 GB SATA SSD
