Computer overhaul
27 Sep 2005
Cornwall / Helston
Right ive decided to upgrade my pc in the next 3weeks and was looking for something like the following. i dont plan on going sli so 1 pcie slot will do. i dont have a strict budget but would like to keep the price down.
how does this look?
Akasa Eclipse 62 Aluminium Case - No PSU £79.99
(£93.99) £79.99
(£93.99)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £69.99
(£82.24) £69.99
(£82.24)
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail £162.99
(£191.51) £162.99
(£191.51)
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £329.99
(£387.74) £329.99
(£387.74)
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £95.99
(£112.79) £95.99
(£112.79)
Sony AW-G170AB2 18x DVD±RW x12 Ram Dual Layer DVD-Writer - (Black) OEM £14.99
(£17.61) £14.99
(£17.61)
Sub Total : £753.94
Shipping : £10.95
Vat : £133.86
Total : £898.75
Go for either an E6300 or E6400. The E6600 isn't really worth the extra.
And if it's back in stock by the time you order, you might as well go for the cheapest GTX. There's no difference, just a brand sticker.
Edit: You'll also need a PSU. Corsair 520W should do.
the e6600 is worth the extra imo if you have the money get it
