ok i am just wondering if you know the problem with this,in my computer i just put in the A8N32-SLI Deluxe motherboard, a Nvidea 7950 GX2 1gb graphicscard, then i gave it a new case, and installed xp, i put in some new akasa thermal compound on the CPU, everything was great and running fine, and then i installed the asus pc probe which tells you all *** Tempretures, the cpu was 32 and the motherboard was 29 i didnt think much of it, then i installed test drive unlimited and played top specs perfect, but then all of a sudden the computer shut down, so i started it up again, then within 4 or 5 mins it shut down again, so i thought this is odd, so i checked inside the computer and everything was fine, so i started it up again and went into bios and looked at *** cpu temerature and it was at 52! i NO SWEARING myself, so i shut it down asap, then after about a hour i started it up again, worked ok, but then i opened pc probe and it was going up and down from 40-50 degrees the motherboard and cpu temerature, but as soon as i put a game on, the CPU went to 60 and the motherboard was at 50, and after about 5 mins it shuts down (obviously the motherboard or cpu protecting itself from *** heat) i have 2 case fans the heatsink fan on *** cpu which is running at full 3169 allso the heat pipe fan and a extra case fan, but nothing changes, theres no jerks no nothing to tell that its gonna shut down but its definatly bcus of the heat, ive been told a couple of things like it could be one of the sticks of ram could be broke so i tried this MEMTEST and about 15% done and the Temp jumped to 66! the highest its ever been and shut down, so its as far as i have read it could be them but also ive heard it could be the cpu fan, but its sitting fine and running full speeed, but a question i would like to ask is if its the RAM broke why does *** cpu overheat ? (i have 2 ddr400 514mb sticks) so all in all its overheating but the thing is i want to know is whats making it overheat, (i was thinking about watercooling it but since ive been reading i dont know if that will help ?) so question is giving you all the infromation ive gave you what is more than likely the problem ? allso is it true that *** RAM could be the problem of this ?
would be amazingly greatful for all yoru help cheeers my email is [email protected]
, as you can see im all new to this
