- 11 Oct 2005
- Derbyshire
Okay I have a Computer problem and I am after some diagnosis.
I am not too bad with computers, I have built quite a few my self but not that good at narrowing down problems if they wont start.
Right this computer is from my sisters (vet) works. All they have told me is wont start up.
I am 99% sure,, or so I am led to believe it is running Windows 2000 O/S
It has on it a CD Drive, Floppy Drive, Zip Drive, Network card, Modem card, 2 x Hard Drives and that is all I know.
I have connected my monitor to it,
If I have BOTH hard drives connected I see nothing on the screen. Hard drives are connected through ribbon cable with master and slave.
If both HD are connected no POST etc. If I unplug slave (power cable) HD then I get to 1st screen. But then nothing, screen just goes off to standby. (My OSD on screen says DPMS. going to off mode)
The 1st screen all I can see says the following on it (black screen)
American Megatrends released 08/01/2001
AMIBIOS ©1999 American Megatrends Inc
7VMM F4
AMD Duron ™ Processor – 850MHz
122880kb OK
WAIT…
Auto detecting Pri Master…IDE Hard Disk
Auto Detecting Pri Slave…Press <ESC> to abort
Press any key to continue.
The only thing that happens next (eventually is I hear a beep then it should start to load the OS but I just get nothing, screen goes to standby as no signal, I can hear the hard drive trying to do things, but nothing ever appears on screen.
I have left it a long time just in case it is a very slow computer and still nothing.
I can press F1 at start up and get to the following screen
AMI BIOS Flash Utility v1.03
Flash ROM Type………………..HYUNDAI HY29F002T
I have the option LOAD BIOS from floppy
And ENTER>Run ESC>Reset F10>Power Off
I have reset CMOS and nothing changed, not tried searching the net for the BIOS yet, perhaps someone here can help
Thank you a lot hopefully
7VMM F4
122880kb OK
WAIT…
