Computer randomly freezing for 30 seconds.
Permabanned
18 Oct 2002
Derbyshire
I normally manage to work out what is causinga problem but in this case have not yet managed to work it out.
My computer keeps freezing up randomly
and i cant seem to put it down to any one thing where is the best place to start looking ?
it normally locks up except for the mouse then about 15 seconds later the mouse will also lock up and then after 30 - 60 seconds it acts normally again.
Thanks
James
kcer said:
what are you normally doing when it locks up?
Completely random up to this point.
Temp is fine
done a virus scan
services are the same services as has always been
this has only recently started happening.
Spyware? Often not picked up by a standard virus checker.
Any hard drive activity when it happens?
Any netork activity?
Any cpu activity?
<maddness> said:
is there a lot of hdd activity when this happens?
the hdd light flashing or on?
Cant tell if there is a lot of HDD activity as its so quiet and i never know which way to plug the hdd led into a mobo so just guess and the pump for my wc is in the way of my swapping it around.
always some cpu activity yes and always network activity.
I am constantly streaming either some form of music or video over the network and also msn
at a guess i would say the hdd is normally doing something as well
A bit hard to tell then. Basically you have constant hdd, network and cpu activity. I don't suppose you're running a Java application such as Limewire? They can sometimes cause pauses as they "garbage collect".
