- 24 Feb 2004
- Leeds/Cyprus
I'm at the end of my tether with this guys, would appreciate any suggestions you had. My PC was just idling there while I was talking on the phone (not even any background apps running apart from the usual like anti-virus, Google Desktop etc.) and it blue-screens, reporting an error caused by atapi.sys!
I tell myself, ok nm, it's been running for a few days straight now without a single reboot, so didn't think much of it, but on restarting, it reboots itself again a couple seconds after the Windows splash screen appears! I try again in Last Known Good Config and exactly the same happens, I try again in Safe Mode and this time it takes much longer to reboot, showing a scrolling list of several hundred drivers, apparently hanging after giveio.sys and rebooting a minute or two after that. I then try resetting my BIOS to defaults, and that made absolutely no change at all either. (All speeds and voltages were at stock anyway, and CPU temp was at 35C in BIOS so that can't be it)
Computer is an E2180 on a Gigabyte P35-DS3R Rev1.0, with aPowercolor HD3850 and 2 SATA HDDs, powered by an Antec HE 500 and running XP SP2. It's been running stably for days, gotten its virus and spyware scans, eaten its veggies, and had no new software installed on it apart from Skype 2 days ago and Dawn of War Soulstorm 3 days ago (which I played a few games of last night and it didn't cause any kind of crash), neither of which was running this morning when it BSODed.
I'm really puzzled by this guys, desperately need some input. I'm hoping it's just an OS problem and can be fixed by doing a repair-install of Windows, but I can't for the life of me imagine how such dramatic OS corruption could've happened while the computer was just idling there! And if it's a hardware problem instead I really need to identify which bit it is so I can get a long-enough run up to help me stick it far enough up the manufacturer's rectum, so any tests I can run please suggest them no matter how wild and off-kilter they may sound!
