Recently upgraded my computer, new motherboard, CPU, RAM.
Setup:
CPU(new): Ryzen 5 7600
Motherboard(new): MSI MAG B650 Tomahawk WIFI
RAM(new): Corsair Vengeance DDR5 32GB 6000Mhz CL30
Case(old): HAF X
GPU(old): NVIDIA GeForce Aorus 1080Ti
Cooler(old): Noctua NH-D15 with offset bracket for AM5
PSU(old): Corsair RM750
SSD(new-ish but came from old setup): Samsung 990 PRO NVMe M.2 2TB
Operating system: Windows 11 (previously used Windows 10)
Monitors: 144hz BenQ XL2430T, 60hz BenQ GL2450H
Installed new components and everything posts/starts up fine (a bit slow but I think normal for AM5). After starting it up, about 20-30sec from logging on, my pc stutters/lags (barely useable but I'm posting here on it atm). It's noticeable just moving a browser/file explorer window around that it's choppy, watching a stream/youtube/video file the audio is laggy and the visuals are also choppy. Sometimes the problem just goes away after 20-30minutes, and I can use my PC fine and play games for 10-12hours straight no issues. Sometimes it doesn't. If I restart my pc or turn it off and on, the same situation happens and the stuttering comes back. I tried putting it to sleep and resuming once and the problem didn't come back.
I don't know what's wrong, or where the problem is coming from. I've had suggestions such as it being windows/drivers/power plans. I've re-installed Windows 11 again, reinstalled the latest chipset, used DDU and reinstalled latest GPU drivers, set windows power plans to maximum performance, unplugged unnecessary USB devices, tried with X.M.P. on+off. Nothing fixed it. I sent an etl performance file to one guy who said he thought it was my GPU, and whether I'm using a pci-e riser (I'm not), but that's the closest I've been to anyone locating the source of the problem. I've have latencymonitor and windows performance recorder/windows performance analyzer installed but I have no idea how to use analyzer to identify problems. Happy to message the etl file if someone thinks they can identify a problem. System interrupts are taking 5-12% of my CPU, CPU0 has very high usage (around 90%) and CPU1 is getting worked a lot too (~50%). Even so, my overall CPU is only 15% usage on idle.
I don't even know if it's faulty hardware or software at this point, or why my computer would sometimes decide to 'work normally' after 30mins of the stuttering where I can play games etc. fine and get high FPS (wouldn't this rule out hardware being an issue?). I've been switching on my pc every day, going afk for 30mins and praying I come back to my pc deciding to work so I can use it for the rest of the day. Sometimes it does, sometimes it doesn't (today it hasn't yet). Instinctively, it feels like something (perhaps my GPU?) is having some weird handshaking issue with my system that it struggles to resolve, causing a huge backlog of system interrupts that sometimes gets resolved/clears and everything can work fine (complete guesswork), and other times it doesn't.
Latencymon main report: https://i.imgur.com/flgWoMl.png
Latencymon drivers tab: https://i.imgur.com/H3PvC8Q.png
Latencymon CPU tab: https://i.imgur.com/xbJ3SNk.png
Setup:
Case(old): HAF X
