computer totally screwed...
25 Nov 2004
i just came home and turned of the computer after clicking profile it takes ages to load eventually comes onto desktop with everything gone...background etc. there is still a lot of files and i can get onto internet...
rofl wtf? sporkeh?
a bit of a vague question really - what's loading with wndows?
What is the hardware?
Have you checked the drives are working ok (DMA mode, no SMART warnings), and your memory is still registering correctly.
nope i really wouldn't know where to begin...i have had random problems with this harddrive in the past and its included having to formatt a lot etc.
i'm guessing a formatt and reinstallation will fix it :/
if it was a memory problem it wouldn't effect files would it? i'd say corrupt HD or virus
ive just noticed in 'local disk' is a txt file called 'error'
never seen this before :o
*it was created yestaday and modified 24 hours later in the same hour*
if the drive has been problematic in the past then the chances are reformatting it and reinstalling isn't going to sort it out in the long term and i would be very wary of using the drive if it was giving problems.
I would suggest downloading and running the manufacturers test utilities for the drive to try and see if that is indeed the cause of the problem.
