Hi, I have the same setup for about 2 years and everything was working fine until today. I switched on my PC, the motherboard lights switch on, all the fans are spinning but it wouldn't post.
At first l thought it was my cable or monitor. I hooked my laptop on the screen and the screen works fine with it using HDMI->DVI cable. Then my suspicions turned to my dedicated video card. I removed that as well and hooked the HDMI cable on the motherboard's HDMI output. Again the same problem. I tried clearing the CMOS with no successful result. If l only connect the monitor with no USB devices it sometimes manages to reach a prompt telling me that it is using fail-safe settings and that l should press F1 to enter setup or F2 to continue but since no usb devices are connected l can't do anything.
I am at work now and l will start removing devices, test PSU when l get back home.
Here are my specs:
Motherboard: MSI Z77A-GD55
CPU: Intel i5 3570K
RAM: Corsair Vengeance arctic white 2*4GB
PSU: Corsair TX 750W
GPU: ATI Radeon 6850
HDD: 1 ssd & 2 mechanical drives
Everything was running at stock, only using XMP profile for the RAM.
Here are my specs:
CPU: Intel i5 3570K
