6 May 2012 at 11:06 #1 BenJ BenJ Associate Joined 10 Aug 2006 Posts 704 Location Warrington PSU has died. Tested with another. I will replace it but its on a Dell system and the PSU is some off small thing, not like in a normal desktop. What are these called?? Last edited: 6 May 2012
6 May 2012 at 11:09 #2 opstrat opstrat Soldato Joined 26 Aug 2010 Posts 3,516 Location glasgow so u have tested the motherboard with 2 different psu's and get the same results?
6 May 2012 at 11:17 #3 BenJ BenJ Associate OP Joined 10 Aug 2006 Posts 704 Location Warrington **EDIT** My mistake it was the psu faulty. Last edited: 6 May 2012
6 May 2012 at 11:22 #4 pandem0nium pandem0nium Soldato Joined 5 Dec 2010 Posts 3,212 Location Solihull Faulty RAM would boot but not post, and give you a beep code from the internal speaker normally. I've never had an amber light on the MB, but it doesn't sound good! I'd try any find the manual.
6 May 2012 at 11:26 #5 BenJ BenJ Associate OP Joined 10 Aug 2006 Posts 704 Location Warrington **EDIT** My mistake it was the psu faulty. Last edited: 6 May 2012
