- 8 Jan 2009
My system was working fine until this morning, when I decided to tidy the computer room up.
I disconnected my pc and moved it into another room, took off the side and cleaned the dust filters on the intake fans.
This evening I put it back into the computer room and it just won't start up.
When I turn on the power supply at the switch at the back, the mobo lights come on and the little lcd poster thingy says 'Welcome' and then starts counting time from when power was applied.
When I push the case power switch, nothing, zilch, nil.
I've checked the switch with a multi meter and it seems fine, I've even tried shorting the pins on the mobo, but still nothing.
I disconnected my psu and shorted the pins in that and it springs into life no problem, so I'm ruling that out.
I've had a good look round and can't see any loose wires, and have rechecked any connections I can see.
I beginning to think the mobo is borked, why, I don't know.
Anyways, it's an Asus Rampage II Extreme with a Corsair 1000w Psu.
Any body got any ideas of anything else I can check out?
Damn, that old saying 'if it ain't broke, don't fix it' is ringing round the inside of my head.
Thanks, Jonney.
Thanks, Jonney.
