Computers hanging on applying personal settings
Permabanned
10 May 2006
Northern Ireland
Hi Folks,
I'm not overly sure if this is a server or workstation issue however it seems like the former. In the last week or so a few of the workstations in the office are hanging on "Applying Personal Settings" after they login.
It will sit there for anywhere between 3-15 minutes, I've restarted the domain controller but to no success. Has anyone seen this happen before or can anyone shed any light as to why it may be happening?
Thanks
DQ
Check the client DNS settings and make sure your domain controller(s) are working and replicating properly - do a dcdiag on them.
Are you using roaming profiles?
The issue was actually a DNS problem. The router at this location had its two ISP dns servers selected first, and our internal DNS server third, no idea why it was set like that. Swapping the order on the DNS entries solved the problem, it now logs on in about 15 seconds. Thanks for the help fellas!
The clients should point at the server for the DNS and the server should have forwarders setup for the router/isp dns whichever way you want to do it.
Agreed - using the DNS forwarding on the router's a bit daft. In the DNS server properties you can specify your ISPs DNS server as a forwarder for "all other domains", then point the clients to the DC - thats best practice.
I have it reconfigured just as you've described it, I've no idea why it was configured via the router. It was my predecessor who set it up and he's no longer here for a reason :p
Ah, predecessors, the bain of my life!
Yup.
I've been into a site running SBS2003 with exchange ready to go but the users still collecting mail from POP because he was too lazy and/or lacking knowledge to fix their public IP and set-up the domain to point at it for proper SMTP.
