comuter keeps crashing
27 Aug 2006
this is a most for a mate
his computer keeps crashing and frezzing and giving BSOD he updated his computer from (this computer is running windows ME)
AMD Athlon(tm) XP 2600+
256MB RAM
MSI MS-StarForce GeForce4 MX 440 with AGP8X 64 mb
then he updated the ram to 768mb he added 2x 256 sticks
and the gfx card to MSI MS-StarForce GeForce4 MX 440/MX 440SE 128 mb
the up dates were of the bay
any no how to fix this
weve tried geting drivers for the gfx but none work
any help would be apreciated
troy
A couple of things to check for:
Is his system overheating? When my old CPU started to overheat using ME i used to get a lot of hangs and reboots. I fitted a new cooler and it was mostly fine afterwards.
How long since he reinstalled ME? I never did like ME and found I needed to reinstall it at least once a month, otherwise it became too unstable.
Download http://www.ubuntu.com/ - burn to a CD and run it from the CD. It contains Memtest on the CD and also runs Linux straight off the disc with no need to install. If Memtest is error free and Ubuntu loads and is stable I'd put it down to ME. If it's not stable under Ubuntu, you know it's likely a hardware problem.
i have a that disk
ill try it
how long does mem test take
and any other sudgestions
What PSU has he got? I had problems with a PC upgrade because I didn't know to upgrade the PSU as well. I was running a 1.6ghz with 512ram and 128mbgfx etc on an old 250watt PSU lol
