- 15 Feb 2013
- Edinburgh
Hey all,
Putting together my PC build I notice that I (Stupidly) completely overlooked that my res is not above the pump .
To be honest the pump is higher as it's on a Shoggy Sandwich, I can raise the res up so they are parallel, maybe a touch higher but I'm concerned that the res might not feed the pump enough.
The pump's a D5 with an EK top and the res is the xspc photon tube (mounted Horizontally)
Will the res feed the pump enough? or am I going to have to re-arrange the lot?
Thanks
Thanks
