Well I recently splashed out on a i7 overclocked to 4GHz and a corsair h50. I am rather concerned though over what seem to be excessive temperatures under full load the cores will idle away at around 47 degrees but under full load this shoots up to around 80-85. Im not sure where I'm going wrong here as most people seem to report much better results from this cooler. I'm running in what should be a well ventilated coolermaster 690 case with 3 intake and 3 exhaust fans. I've tried mounting the supplied corsair fan as intake and exhaust (it generally spins at about 1600rpm) I've also tried two 1300rpm xsilence fans in push/pull exhaust configuration. Most reviews suggest the latter config but any seems to make no more than a few degrees difference.
This may be a noob question but I know nothing of the mechanics of watercooling but I notice when I move the radiator water sloshes around inside is this normal I would have assumed the circuit would be full?
Any help/suggestions much appreciated.
