Hi
I have just built a new PC and have downloaded SpeedFan to have a look at the temperatures.
These are a summary of the results I get
Temp1 48c
Temp 2 30c
Temp 3 24c
Local temp 40c
Remote temp 32c
Core 0 66c
Core 1 64c
This PC is a E6300 with two Akasa 120mm amber fans and a tuniq 120 installed.
Now I am obviously concerned with the temperatures of the dual cores and whether I haven't installed something incorrectly? Am I correct in being concerned and any ideas how to lower the temp if it is a problem?
Thanks
Temp1 48c
Temp 2 30c
Temp 3 24c
Local temp 40c
Remote temp 32c
Core 0 66c
Core 1 64c
Thanks
