I have a Beko 8kg condenser that I got from currys.
It cost me £210 at the time but I think its over £250 now. I really like it as it comes with a hose you can pull out and attach to a drain, meaning you never have to empty the condenser bit out. Super handy!
Link to the exact model? Ta
I have never seen a dryer which doesnt have this featureI have a Beko 8kg condenser that I got from currys.
I'd avoid putting the dryer on at night, with it being the most likely appliance to burn you to death in your sleep.If I were using one regularly would definitely consider getting a smart meter and using the 7p/Kwh night units you can get, you can even pay more for the dryer reliability offset by unit costs.
earlier threads - probably not whirlpool ... although don't think it was their recent factory fire
I have never seen a dryer which doesnt have this feature![]()
Depends on the dryer you need to look carefully at the condenser performance as they are definitely not all equal. We have a Bosch one as it was one of the best in terms of actually condensing!I've been looking in to these and lot's of people say they chuck a lot of moisture out in to the room. Where ours is going is a smallish room with bugger all ventilation so am wondering if it makes more sense just to go vented and drill a hole in the wall if I've got to drill a hole in the wall for ventilation anyway....
