- 27 Dec 2005
- Bristol
Can anyone spec me a condenser tumble dryer for our spare room and/or makes to go for? Budget up to about £250 after looking at a few.
It would be worthwhile investing in a good energy rated dryer just because they cost a fortune to run and also an intelligent one that turns the heat down and stops what the clothes are dry rather than just keep turning long after they have fully dried.
http://www.johnlewis.com/bosch-clas...-dryer-7kg-load-b-energy-rating-white/p575576
Something like that
Unless you go for a heat pump condenser, they're all energy rated as B at best. Heat pumps are out of his budget though.
I recently recommended a Beko 7Kg condenser on here but since doing so it has failed twice on us. I have just ordered an LG to replace it. From my research, Bosch, AEG and LG seemed to be amongst the more reliable condensers.
Gilly said:We've got an 8kg Hotpoint and it's been great for the 18 months or so that we've had it.
It's got ready to wear/cupboard dry settings and is adaptive for material types and how wet they are.
