- 25 Jun 2005
We've got this Bosch Condensor Drier arriving later today.
We live in a first floor flat. They are basically old large victorian terrace houses that were divided into 2. All separate (no communal areas) entrances/exits.
We have at the back of the property a make shift utility room which is on ground floor level, this (was once the old coal shed/outside toilet) is the rear entrance/exit to the property with a staircase leading down out of the kitchen. It's difficult to visualise hence the detailed description! It's part of the property as such and is secured/alarmed. People who I've described it to then have seen it have pretty much always said something 'I see what you mean now'.
The space is about 3 metres long x 1.5 metres wide x 2 metres high, it is powered, decorated and shelved out and is incredibly useful. It is not heated, as such it can get cold (getting a thermometer tomorrow). There are no windows, but is properly ventilated. The space us currently used for storage (washing powder, loo rolls and the like), tools etc.
This is the space where the new drier is going to live (along with a freezer to be ordered next month).
I have just bought an Dimplex 2 KW oil filled radiator to go down there as well to keep the chill off. It has an integrated timer and thermostat. When I first plugged it in I turned it up to max and left it for 30 minutes, nice and toasty so the rad has no issue heating the space at all, that said what is going to be the most efficient use of the radiator?
Constantly on at a low temp?
Turn it on an hour before the drier will be used and whilst in operation?
Leave it on the frost setting, so it only comes on if the temp drops below 5 degrees?
Or use the timer and have it come on for an hour or so 3 or 4 times through the day/night.
The radiator will only need to be on September through to May at a guess. I just want to protect the drier, but which way would be best and most cost effective?
(yes I know why, just thinking out loud)
