Conditional routing over PPTP help required
1 Dec 2002
Swindon
Im trying to configure my PPTP client (ubuntu) to only send traffic to IP x.x.x.x over PPTP, the rest directly out from my internet connection - but it is either all or nothing.. Any idea how I can configure PPTP to work in that manner?
Don't add your PPTP VPN as the default gateway, then add a static route to send traffic for your specific IP over that interface.
@Caged, OK I think I know what you mean.. By PPTP as default gateway do you mean dont add this command:
sudo route add -net "0.0.0.0/0" dev "ppp0"
? This as far as I can see would send all traffic to PPTP.. I have tried adding a specific IP to the route add command, but it returns an error, so I am obviously doing something wrong:
sudo route add -net "x.x.x.x" dev "ppp0"
SIOCADDRT: Invalid argument
It would be useful if somebody could tell me the command to run to pass all traffic from x.x.x.x to "ppp0". :)
PS: I followed this tutorial for installing PPTP, which works fine, but doesnt go into details for adding conditional routing.
Yes -host updates the routing table, but it still doesnt appear to work.. I will try to route something easier to debug first of all, then see..
Thank for your help @Caged. :)
I think you might still need to give it a gateway, in your case this will be whatever your gateway address was changed to when you established the VPN and it wasn't a split-tunnel configuration.
