- 18 Oct 2002
- Somerset
In a current set up we have two banks of switches on oposite sides of the site,
These banks are connected by two cat5e cables running at 10/100 (due to switches), all the switches are unmanaged and so the two connections just operate on there own,
I am adding a 10/100/1000 managed switch at each end and the two cables connecting each bank are one of the things that will be moved to these switches.
My question is will i be better setting it up as it is now with two independant connections, or trunking these two connections together between the swiches?
If i trunk them and one of the cables goes down does the 2nd keep working on its own or does it bring the trunk down?
Thanks
Keith
Thanks
Keith
