Hi there, I would like to upgrade my old 4400 x2 box. I've settled on the following config:
Motherboard:
Asus P6T Deluxe X58
CPU:
Intel core i7 920 @ 2.66 ghz
GPU:
Ati HD 4870x2 2 gb
Ram:
Corsair Dominator (3x2Gb) @ 8-8-8-24
PSU:
Corsair HX @ 1000W
My questions are:
1. Are there better options around the same price range?
2. Considering I have an Akasa Eclipse 62 v1 case, will I have problems fitting anything in?
3. Do I need a better cooler, or will the one from the box suffice?
4. Considering I have a bunch of older(ish) 8mb buffer sata-2 hard drives, are those enough for optimal performance, or should I get a newer generation one as well?
5. Is my Viewsonic vpn930 good enough to handle all the graphics card can throw at it?
Thank you
Motherboard:
Asus P6T Deluxe X58
CPU:
GPU:
Ati HD 4870x2 2 gb
Ram:
PSU:
Corsair HX @ 1000W
My questions are:
Thank you
