24 Jul 2015 at 21:08 #1 wellibob wellibob Soldato Joined 27 Mar 2006 Posts 4,049 Anyone done this or can advise how to set this up. Look on the Web but need advise on a few things Thanks
24 Jul 2015 at 21:55 #2 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,082 It should be the same as any other router... Assign a suitable management IP Disable DHCP Connect one of the LAN ports to the network Configure the Wi-Fi Are you having a specific problem?
25 Jul 2015 at 00:26 #3 wellibob wellibob Soldato OP Joined 27 Mar 2006 Posts 4,049 Yes I'm not sure what suitable management ip I should be putting in the settings. Advice is needed or simple instruction.
25 Jul 2015 at 00:35 #4 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,082 Your router will have an IP address (e.g. 192.168.0.1). This will also be your network's gateway address. It will be running a DHCP server that issues IP addresses to your client devices in a defined range (e.g. 192.168.0.100 to 192.168.0.200). Your management IP needs to be in the same range (e.g. 192.168.0.???) but selected to not clash with either the router's IP or its DHCP range. In this example you could choose anywhere between 192.168.0.2 to 192.168.0.99 and 192.168.0.201 to 192.168.0.254
25 Jul 2015 at 00:45 #5 wellibob wellibob Soldato OP Joined 27 Mar 2006 Posts 4,049 I'll do some screen grabs as I'm a bit confused to the exact boxes to enter.
25 Jul 2015 at 00:57 #6 wellibob wellibob Soldato OP Joined 27 Mar 2006 Posts 4,049 https://www.google.co.uk/search?q=P...UCh0SoADw&biw=90&bih=143#imgrc=DwZalrWL2fM46M: What boxes do I need to adjust. My main router is 192.168.0.1 (tp link) and ip range 100 to 199 Last edited: 25 Jul 2015
25 Jul 2015 at 09:44 #7 StevieP StevieP Soldato Joined 2 Jan 2004 Posts 7,796 Location Chesterfield A friend of mine has just used an old router (albeit not a Plusnet one) as a wireless access point and found this article very useful. Apologies if I've misunderstood what you are trying to do! Last edited: 25 Jul 2015
