Hi all...
I have a Netgear WGR614 wireless router, connected to a standard cable modem on Virgin. To boost the signal for the laptops downstairs I've bought a Linksys WRE54G range extender to act as a repeater.
It's configured properly, to the best of my knowledge. WEP security is enabled on both, with the correct keys used etc. I've even added the linksys mac address to the access list on the netgear, just in case.
Now, the linksys does appear to boost the signal as the connection speed has gone from 11mbps to 54 on the laptop downstairs. However, it won't connect to the internet when it's using the signal bounced from the linksys. The connection tries to work, then gives the error message saying it has limited connectivity and the internet won't work.
I have read briefly that it might be something to do with dynamic IP allocation, and that the linksys won't do it. If this is the case do I need to configure the laptop to use a static IP? How do I do this? If I do this, when the laptop roams and connects to the router instead of the repeater, as it's on static, will it cease to work? Does the whole system need to be on static IPs except of course for the connection to the cable, which is dynamic only?
I'm confused!
Thanks in advance for any help folks.
Jim
I'm confused!
Jim
