Configuring Samba?
8 Jan 2009
Gidea Park, Essex
Hi Guys,
I'm trying to share files between my two laptop's, they are both debian OSs, Ubuntu 9.10.
I need help to get samba running.
I have done sudo apt-get install samba smbfs
to get the server and client installed on both.
But I also want to configure one system to be able to share files without authentication and the other to share files but you need a username and password.
How can I do this, thanks.
Can you post the contents of smb.conf?
An idea might be to install SWAT since this gives you a nice web based configuration interface for samba which might make your life easier.
Code:
sudo apt-get install swat
Edit: otherwise something like this should work. NOTE: This is probably not secure at all! I only use it because I trust everyone on my home LAN.
Code:
[netshare]
        comment = Network Share
        path = /mnt/netshare
        write list = *
        force user = root
        force group = root
        read only = No
        create mask = 0644
        guest ok = Yes
You'll need to
Code:
chown /mnt/netshare root
ie.chown the /mnt/netshare (or your equivalent) to root (or your equivalent).
