Confirm my worst fears - damaged frame
22 Oct 2005
Moving...
I gave the bike a quick clean today and noticed what appears to be a hole behind the bottom bracket between the seat tube and the chain stays. At first, I thought it might be some weird drainage hole or something similar that I'd not noticed before, but I think that is just wishful thinking. I'm guessing something got wedged in the tyre and was then flung with a crazy amount of force and just tore a hole straight through the carbon :(. I've not had a crash, I didn't even hear any loud bangs/dings either. It's a Vitus Vitesse Evo CRi.
Do you think it's crazy dangerous to ride in this condition, or do you think it should be ok temporarily while I wait for a replacement?
Absolutely gutted as riding my bike is about the only thing I look forward to at the moment, and funds aren't looking too good at the moment :(
Wow, thanks for all the quick and helpful replies.
I've had the bike for 18 months now and have never noticed it before, but yes it certainly looks like a clean hole (as if pre-drilled), perhaps there was a bung that sat quite flush which I didn't notice.
It's in exactly the same spot as the image Dis86 has linked, so I think resurgam could be right in that in that it's for a cable.
Thanks again guys. I can sleep a bit easier at night having spent the last few minutes looking at the price of frame sets :eek:
That's pre-drilled - it has a draft on it. On a carbon frame it would likely have cracks or a ragged edge as the failure mode. It may be a good idea to see if anyone can supply a rubber bung to stop water and general debris getting inside the frame.
