confirm please..
19 Oct 2002
wiltshire
can someone confirm for me this is ok, asus p5ql pro mb, E7300 core duo stock 266 x 10 = 2666mhz, ram is corsair xms2-8500 1066MHZ 5-5-5-15, i overclocked in bios by just changeing fsb to 319 and vcore to 1.36250, everything else on auto in bios, ran prime95 12 hour's useing blend setting, so is below ok, or do i need to change anything, is ram settings ok, i mean getting the most out of it, or am i ok just to leave in on auto for ram in bios, cheers
Got 75c max temp mainly running prime95 with stock fan, was told as long as it stable the temps are so important, i did reach 80c a few times.
CPUZ shows the following
319 x 10 = 3190 core speed
319 bus speed
1279 rated fsb
v.core shows 1.320v
memory shows
dram freq 398.8MHz
FSB: DRAM 4:5
