Confirming Graphics Card Has Failed
6 Apr 2009
Hello,
I purchased a Sapphie Radeon HD5670 Graphics card around December (I know it's not the best, but was an upgrade for the family computer from the on-board one it had at the time).
It has worked perfectly since then, until today. I was browsing eBay, when the screen flickered and blue screened for no reason.
I have tried to restart the PC, which is fine up until where the windows cursor should first appear where instead it blue screens, unfortunately I cannot read this blue screen as it only shows for a fraction of a second before rebooting itself.
I have removed the graphics card and reconnected to the on-board one, to which the computer boots as normal.
I have tried resetting the BIOS settings etc, but the same problems happens when the HD5670 is in.
Any help would be appreciated
Kind Regards
Hello,
I started the PC up with the graphics card in, and the blue screened hanged enough for me to read something about drivers in the top line.
I then removed the graphics card, and now get the blue screen with "MEMORY_MANAGEMENT"
Any ideas?
Regards
it doesnt seem like its a graphics card issue IRQ is a CPU/MEMORY issue mostly.
i would check your memory and cpu.
