Hey guys -
So I'm going to be building a new PC for the new year -- and decided to try water cooling for the first time ever. I've been reading everything I can find for the past two months and I think I'm finally ready to start placing my orders. I wanted to run this by some of the "experts" first though, to make sure I don't run into any problems. So, here I am...
Case: HAF 932
CPU: Intel i7 920
Motherboard: GIGABYTE GA-EX58-UD5
Memory: 12G ( Corsair HX3X12G1600C9 )
Radiator: XSPC RX360 (I could be convinced to go with Thermochill PA120.3 instead...)
Pump: MCP355
Reservoir: XSPC Acrylic Reservoir for Laing DDC; I'm still not sure I understand how this reservoir top goes on top of the MCP355, but I'm assuming I'll be able to figure it out when I have the parts in hand, right?
CPU Water Block: HeatKiller 3.0 CU
The video card is undecided at this point -- and I probably won't WC it, at least not at first.
So those are the main pieces. The parts I'm still confused on are the barbs/compression fittings and the tubing. I get the impression that any decent tubing works, but I don't know what barbs/compression fittings to use or how to pick the tube diameters. From what I gather compression is easier to use and looks nicer, but barbs are pretty much just as good? Do I need special tools for the barbs? Some posts talk about using a "spanner" - which I don't have.
The other thing I'm worried about is the differences in metal types -- I've read about the corrosion caused by different metals, but I'm having a hard time figuring out what types of metal each piece is using. That's why I'm hoping someone can say whether the components I have listed for my loop are a good fit together.
One more question! I think I need to buy three 120mm fans for the rad, right? I'm not sure where those go -- the bottom of the rad or the top? It's also something I can probably figure out once I get the pieces, but I'd like to know as much as possible now!
Thanks everyone!
Case: HAF 932
CPU: Intel i7 920
Pump: MCP355
Thanks everyone!
