Conflicting memory? Crucial Ballistix
  • Thread starter Thread starter Yao
  • Start date Start date
Yao
Yao
13 Jan 2004
I have the following:
Abit AV8 3RD Eye motherboard
Crucial 1Gb (2x512MB) DDR PC4000 Ballistix Dual Channel Kit
Its been running fine for over a year now. I decided to boost the memory last week and ordered from OcUK the following:
Crucial 2GB (2x1GB) DDR PC4000 Ballistix Dual Channel Kit
When I installed it the BIOS only registered 2Gb. I called up tech support who suggested I reset my CMOS and swap the memory around (DIMM 1/2 for DIM 2/3). When I did this the BIOS only registered 1Gb.
So I now only have the 2Gb Ballistix Dual Channel Kit in and am wondering what the problem is. Can anyone help or give me some advice, please?
Thanks,
Yao
one of the new sticks of Ballistix could be b0rked, as they have a high failure rate in the 2x1GB style. Try putting one stick in after another, booting up with one stick in, then 2 sticks, then 3 sticks etc.
Because 1GB sticks are usually doubled sided, some motherboards don't like them in certain slots (usually 2 + 4 but varies between boards). Have a look at your motherboard manual and there's usually a table which lists the best combinations of single/double sided sticks. But if you have manually set memory timings then be careful as running 4 sticks on A64 can put the memory controller under a lot of stress.
If that doesn't work, memtest the 2x512MB and the 2x1GB separately. If that fails, memtest each stick individually. I'd leave memtest running for approx 6-10hrs minimum. You can get memtest here: http://www.memtest.org/#downiso (download the .iso, burn to cd and then boot off the cd and leave it running).
Thanks for the responses.
I'll try putting the sticks in one by one tomorrow, but since I can run the new 2x1Gb sticks fine without the initial 2x512MB ones would I be right in saying they are working fine?
I also haven't manually set the memory timings. Below is the tables from the manual. I understand the first table and this is fine for me, but the second table I have no idea what single and double ranks are.
2-3. Install System Memory
This motherboard provides four 184-pin DDR DIMM slots for Single/Dual Channel DDR 400/333/266
memory modules with memory expansion size up to 4GB.
Table 2-1. Valid Memory Configurations
Bank Memory Module Total Memory
Bank 0, 1 (DIMM1) 128, 256, 512MB, 1GB 128MB ~ 1GB
Bank 2, 3 (DIMM2) 128, 256, 512MB, 1GB 128MB ~ 1GB
Bank 4, 5 (DIMM3) 128, 256, 512MB, 1GB 128MB ~ 1GB
Bank 6, 7 (DIMM4) 128, 256, 512MB, 1GB 128MB ~ 1GB
Total System Memory 128MB ~ 4GB
Table 2-2. Unbuffered DIMM Support For AMD 939-pin Processor
===Single Channel 64bits===
DIMM1....DIMM2....DIMM3....DIMM4....Maximum DRAM Speed
SR.........N/A........Empty.....N/A........DDR400
DR.........N/A........Empty.....N/A........DDR400
Empty....N/A........SR..........N/A........DDR400
Empty....N/A........DR..........N/A........DDR400
SR.........N/A........SR..........N/A........DDR400
SR.........N/A........DR..........N/A........DDR400
DR.........N/A........SR..........N/A........DDR400
DR.........N/A........DR..........N/A........DDR333
===Dual Channel128-bits===
SR.........SR..........Empty.... Empty.....DDR400
DR......... DR......... Empty....Empty.....DDR400
Empty....Empty..... SR..........SR.........DDR400
Empty....Empty.....DR......... DR......... DDR400
SR......... SR......... SR......... SR......... DDR400
SR......... SR......... DR......... DR......... DDR400
DR......... DR......... SR......... SR......... DDR400
DR......... DR.........DR......... DR......... DDR333
*DR = Double Rank and SR = Single Rank
To reach the performance of Dual Channel DDR, the following rules must be obeyed:
• When installing TWO DIMM modules: Install DIMM modules of the same type and size for
slots [DIMM1]+[DIMM2] or slots [DIMM3]+[DIMM4].
• When installing FOUR DIMM modules: Install DIMM modules of the same type and size for
slots [DIMM1]+[DIMM2], and slots [DIMM3]+[DIMM4].
Yep that was the table I was thinking about. Put your 1GB sticks in where it says DR and 512MB sticks where it says SR. So it will be: 1GB 1Gb 512MB 512MB . DR = Double Sided Memory (1GB and old 512MB) SR = Single Sided Memory (most 512MB now).
Yep. I tried that when I first encountered the problem. The wierd thing is that the BIOS then registered only 1Gb of RAM. I'm suspecting a conflict is happening here. Is it worthwhile exchanging these for a different brand of memory?
I would try the one by one approach, but since putting the 2x1Gb actually gives me 2Gb of RAM it would appear that they are actually working fine.
This is such a pain. :( Is it still worth doing the memtest?
