Confused about conroe.
13 Nov 2003
Cumbria
Can someone post the stock fsb and multi's of the chips. 6300 6400 and 6600. I'm so confused on how they get the speeds of the chip. Other than I'm guessing they use a higher fsb than the 200?
thankyou smids, that clears it up for me. I bought an asrock m/b off MM, and I believe the highest fsb it will do is 300fsb. So I might be better off buying the 6600 when it's available.
I may get another m/b later, just need too find the wife another job, I'm sure she could manage along with her other 2, she only sleeps at night, so she could be earning more money on nightshift in the hospital.
Chivalry is not dead after all.
I'm sure she'd be HONOURED to help fund your computing needs. More power to her, I hope she gets as much satisfaction as you will.
Raj said:
I know this is a bit of a hijak, but it is worth buying the 6400 over the 6300, its only £30?
The extra multi might well help in overclocking as you do not need as high fsb to get the same clock.
I get that basically say i get a gigabyte ds3 and it can hold a FSB of 400, it follows that:
E6300 = 7 X 400 = 2.8 Ghz
E6400 = 8 X 400 = 3.2 GHz
But in real terms how much differance would i see between the different clock speeds? Anyhting noticable in games/multitasking, i do not really encode that much other then the odd DVD.
How did you miss the bit on the Conroe page where it tells you the stock speeds? :confused:
Intel Core 2 DUO Extreme Edition X6800 "LGA775 Conroe" 2.93GHz (1066FSB) - Retail (CP-130-IN)
Dual Core Technology
- 2.93GHz clock speed
- 4MB L2 Cache
- Intel Speedstep Technology
- EM64T 64-Bit Technology
- Execute Disable Bit
- Cooler running technology, less heat and less noise!
- Supplied with Intel referance heatsink & fan
http://www.overclockers.co.uk/acatalog/Intel_Pentium_Core_Duo2.html
