What is the difference between the 780ti cards currently available on overclockers ?
i can see the spec differences, for example some have 876mhz core and some 1020mhz. also some have 1752mhz shader clock whilst others have 2040mhz
what does this all equate to though ? what kind of fps gain or whatever will i get from fast core and shader clock ?
I will be gaming mainly at 5760x1080 and like to use lots of AA forced via Nvidia Inspector. Is there a particular 780ti which would be better suited to that than other ?
I dont really want to spend more than i need to, i just want to know if the benefits between the cheapest ti and say a £640 one are worth it.
