Confused, best Ram settings.
  • Thread starter Thread starter MJ
  • Start date Start date
MJ
MJ
26 May 2005
Southwest
I am trying to get the best RAM performace i can, i have been reading and please correct me if i am wrong, that a 1:1 FSB ratio is best. No wi just cannot seem to get that no matter how much i fiddle with the BIOS.
I have a Q6600 2.4ghz, running on a P5KSE/EPU board and 1GB OCZ DDR2 PC2-6400 Platinum Revision 2 Dual Channel RAM x 4. (All spec below)
What do i need to set in my bios for the best settings, I have adjusted the timing and set the voltage to correct ammount but i am still getting a ratio of either 2:3 or 3:4. Any help would be great.
Q6600:
Processor Specifications:sSpec Number:
CPU Speed: 2.40 GHz
PCG: 05A
Bus Speed: 1066 MHz
Bus/Core Ratio: 9
L2 Cache Size: 8 MB
L2 Cache Speed: SLACR
2.4 GHz Package Type: LGA775
Manufacturing Technology: 65 nm
Core Stepping: G0
CPUID String: 06FBh
Thermal Design Power: 95W
Thermal Specification: 71°C
VID Voltage Range: 0.85V – 1.5V
OCZ RAM:
800MHz DDR2
CL 4-4-4-15
(CAS-TRCD-TRP-TRAS)
Available in 1GB modules and 2GB (2x1024MB) Dual Channel Optimized Kits
Unbuffered
Platinum Mirrored XTC Heatspreader*
Lifetime Warranty
1.9 - 2.1 Volts
240 Pin DIMM
