Confused by too much OC & Fan Sofware? 3900X, Aorus Elite
14 Aug 2005
Northampton
I've been happy with my prebuilt Overclockers PC now for some time but I would likew to check that my fans and temps are aok?
The challenge I have is that I don't really know where to look properly!
On my system I seem to have multiple places to look at Temps and Fans! I have HWMonitor64, Gigabyte's System Information Viewer, the actual Bios, Gigabyte's EasyTune, AMD Ryzen Master, then as I have Corsair kit I also have iCue.
My Bios Smart Fan 5 setting is "Normal".
I tried hitting all my Cores with a heavy Handbrake encoding session and I was seeing CPU load around 70% and sustained temp of 51 degrees C?
Wondering what I should actually be looking at and whether I should be thinking about a Fan Curve in Bios or the custom Power Plan (forgotten what it's called).
Personally I just use MSI Afterburner and HWINFO64 for monitoring GPU and CPU useage and temps.
I use a combination of the two as well for OSD and system tray purposes.
