Hi
My PC (in sig) is playing silly buggers with me and im utterly confused.
As stock my CPU runs at 2.13Ghz with an FSB of 266Mhz
Ive over clocked it to 3.2Ghz by simply upping the FSB to 400, and its run happily at this speed for well over a year. Occasiaonaly when it boots it will restart and loose my overclock, or sometimes if we get a power cut, but it was as simple as just putting the OC setting back and it worked.
Today I turned it on and the BIOS boot screen showed the stock 2.13Ghz (8x266Mhz) speed, so I entered the BIOS and put back in the 400Mhz speed, and rebooted, but now the BIOS boot screen is showing 2.14Ghz (8x267Mhz) which is random and wrong. So I went back into the BIOS, and the BIOS settings show a 400Mhz FSB and that the CPU is set to run at 3.2Ghz... so i log into Windows and CPUz reports 2.13Ghz (8x266Mhz)... Im confuzed!
The BIOS is set to one thing, the boot screen is showing another, and CPUz is showing different again!
Im all confuzled!
Im all confuzled!
