- 14 Apr 2008
Hi
I have started to build a new pc for my brother.
We are using his old HP Case! & Psu and also the HDD and Dvd Drive
But anyway when i came to connect the USB and Audio and Power up , I couldn't. I am confused.
When I built my own pc( PQ5 Pro and Antec Sonata) I got a system panel connecter and plugged the on/off connector etc in to that, but on this build, i didn't recieve a panel connector ( AMD System, Asus M3A78 board, micro ATX )
So I don't know where to plug the power button into , Do i need a System Panel Connector, I looked in the guide the mobo came with but it doesn't really shed any light on it but it does show the place where a panel connector can be used. I don't get it! Surely they should include one!
But also, it doesn't list one in the , in the box section if you like.
I also don't understand how i would connect the power button to the connector as it is a 10 port thing?
