I have a fairly old HDTV which supports 1080i and i'm looking to get a new GPU soon to replace my 7600GT.
A few questions though.
1.) Is DVI>HDMI that much better than VGA>VGA? For instance I run a HD quality movie on my PC, will the picture be worse with VGA/VGA as opposed to DVI>HDMI?
2.) Can I run DVI>HDMI on my old 7600GT? If I run DVI>HDMI through my 7600GT, is it likely there will be no sound/picture as the card isn't HDCP compliant?
4.) Are HDCP graphics cards able to transfer audio via DVI>HDMI? If so, is that the only unique selling point if there is no difference with VGA>VGA?
5.) As I see a few graphics cards with HDMI ports now, is HDMI>HDMI any better than DVI>HDMI? Does HDMI>HDMI mean sound is definitely transferred through to your HDTV?
