Confusing cam belt change intervals...
12 Apr 2007
Bit of a strange one, I have a 14 year old micra (1.2 petrol) that I inherited from my nan, that I now use as a daily drive as its super cheap to run.
It only has about 30k miles on the clock.
Given its age I was thinking about the timing belt, even though it's very low millage for its age - but the service shedule in the owners manual only says 'inspect every 2 years and replace if nessesary' - it doesn't seem to have a a fixed replacement schedule.
It's had 11 services in its 14 years, all at the same indie garage, but just basic oil & filter services, from what I can tell, so I have to assume they didn't really pay any attention to the timing belt?
What to do?
As it will probably cost more than the car is worth at this point, I'd advise a new car instead.
lol, Nah, I know its history.. my nan owned it from brand new and it spent most of its life in her garage... it's basically in brand new condition, it had a new battery before she died and 4 new tyres too - the tyres were only replaced due to age, rather than wear
At a guess it's probably worth about 2 grand, what's a timing belt/pump change on one of those? less than £500 I'd guess....
It's far more economical for me to maintain it, rather than spending thousands on a newer car that would cost more to buy and run..and despite being a boring car it suits my needs perfectly, I don't need anything bigger or faster etc.
:D
You know the car, it's history and condition. Well worth keeping in that case unless it has something major go wrong.
Also quick search shows it may have a timing chain that can last the life of the engine.
Usually it's 10 years, I had the one on my Volvo done recently, that was 11 years old although only about 50k mileage.
The guy said it wasn't too bad, but I guess you never know really unless you are capable of inspecting it properly.
It's up to you really.
Ahh thanks - that might explain the vague suggestions in the owners manual... I didn't think timing chains were a 'thing' on these.
I guess I'll need to figure out for sure if its a chain - if it's a rubber belt, I'll have it changed I think.
Read some more and so far K12/13 petrol engines all have timing chains. Strengthened on later engines. Misfire may show stretched chain but very unlikely on your low mileage Micra.
Only the diesel engine had a timing belt.
My sis was asking about a starter car for my niece recently and I may have to move the Micra up the list knowing it's likely got a low maintenance timing chain. Worst design is the the wet timing belts on 1.0 Fords.
it's a stuninngly unfasionable and uninspiring car, to be fair - but it does exactly what it's designed for very well - super cheap to run, tax is £30 per year and my fuel consumption is about 49mpg - I did get it up to about 52mpg when I was doing a lot of motorway miles, but don't expect the advertised 60mpg, thats just not realisic in real life... on the roller in a wind tunnel maybe, but not on the road.
Supprisingly well equipt too, aircon, electric mirrors, alloys, Blutooth CD/radio with 3.5mm aux jack if needed - although I don't think mine is the most basic model, I couldnt tell you what specific model it is off the top of my head.
