Because of "Cool and Quiet" This underclocks your cpu while not doing anything. If you run prime 95 it will show its full speed
) It'l run at full speed?Thanks man, So say when I'm running my COD4 at 250fps, (If any of you play promod hit me up) It'l run at full speed?
Yes 3.0GHz as and when required.
I assume you've removed the overclock and gone back to stock settings.
okay =] I take it, it's in the BIOS?
The power savings are huge though. If you can, you should leave it on.
The point sr4470 is making is that CnQ makes the clock speed and volts decrease when idling. So, even though you test stability at full speed and volts, you won't have tested for the clocked-down speeds.
I thought about this and tested with my E7200 for stability at the reduced clocks/volts by running stability progs with their cpu usage throttled by some software (can't remember which one off hand). Turned out it was stable, so I kept it. As I said, massive power savings.
