Hello chaps!
My first Post!
Forgive me if it sounds a bit basic but I'm a tad confused.
I'm running an Amd X2 4800+ (at stock - not very clear about this overclocking business!), with 2 gigs memory (4x 512) and a socket 939 MB.
OS is win XP pro, and currently have a gigabyte 7800GT Graphics card, which seems to work with all my games so far fine (COD2, LOTRO etc).
Was thinking of maybe upgrading graphics card, but i'm not sure if firstly it's worth doing? Will I notice much difference in gaming? Also how do I go about doing it? Buy another 7800gt and sli or upgrade to an 8800gts etc?
Will I be able to use a dx10 card on a windows xp pro machine? or would i need to then upgrade MB, Processor, memory etc (A route I can't afford to go down...) Also is a DX10 card that much better again? Is the difference actually noticebale on the games available at the moment or on new releases coming soon?
As you can see I'm in a bit of a muddle and not sure what to do, maybe I should just stick with what I have and upgrade the whole machine in a years time or so when I get Vista (with service pack 1 or 2).
HELP!
My first Post!
HELP!
