Connect 12cm fans to PVM header on Graphics Card?
13 May 2003
Hamilton
I have a Prolimatech graphics card cooler. It's massive and uses 2 12cm fans. I'd like to be able to control automatically in the same way that fans on the graphics card would be controlled - MSI Afterburner etc.
The fans I have on it at the moment have 3 pin fan and 4 pin molex connections - I assume I'd need to switch to PVM fans to start with.
After I do that, is it possible to connect them both to the graphics card header?
I already have them connected to the motherboard header. There's no way to control them based on GPU temps.
Speedfan doesn't detect my graphics card temp.
