Connect 2 monitors to one vga out?
14 Oct 2009
UK
So basically i want to use two monitors with my netbook and i realise that using a splitter will just result in the same image on both monitors :/ So can i get an adaptor of some sort that can take one vga port and connect to 2 monitors that have a different picture on each....
Thanks
You can get USB to VGA converters, never used one, not sure how good they are.
Best bet is a google search I'm afraid.
