Connect 360
1 May 2003
Bucks
Hi,
After reading the many appraisals of Connect360 in this thread I went to try it out last night. It found my Xbox 360 straight away and works great on the default data folders like Movies.
However my iPhoto library does not reside on my mac but on my external HDD. Is there any way of selecting the location of the libary? Usually with these sort of apps you can select what folders you want to share to the 360, however with Connect360 I can't see any customisation at all?
Unfortunately none of the support or contact links are working on Nullrivers website so I am hoping some keen users on here may know :)
Cheers
Mark
Well I have found the answer on this site:
"If your iTunes or iPhoto library is not found, you can create an alias pointing to it named "iTunes Music Library" in your Music folder. For iPhoto, create an alias named "iPhoto Library" in your Pictures folder"
So hopefully I just need to create an Alias and all should work.
This is going to be another one of those threads with just me in it isn't it? :p
I was going to post something similar to what you found but then I thought that I was getting it mixed up with Front Row so I didn't bother!
