connect to mate via internet? help
29 Oct 2002
stoke-on-trent
Can I connect to my mate who is 1 ,mile away using the internet? We would like to pass files between each computer? Any help would be appriciated.
FTP's a no-brainer, SFTP's the same again with some encryption over the top. SCP's similar idea, but down an SSH tunnel, and FlashFXP's probably a bit pointless for what you're out to do.
Anyone can go google what they mean too.
Mostly depends on what the hell you intend to do with it. For a one off, setting up a server's a lot overkill.
princejim said:
an explanation of the terms and how they work would have been nice, anyone can put in loads of acronyms.
In the same way that anyone can put an acronym into google to find out what they mean and how they work?
I think RomeoS's suggestion is the closest to what you want.
Otherwise, dude, it's a bizarre question you asked!
"Can I connect to my mate who is 1 ,mile away using the internet? We would like to pass files between each computer?"
Like - that *is* the internet! Use MSN, or email, or FTP servers (google for the good ones), I dunno. What exactly is it you want to do?
